22 years agolinux boot copier
Hello, I uploaded microtronix linux binary file into flash. I would like to know if a boot copier (bootloader) is available in order to copy the kernel space into the RAM and after jumps there...
22 years agoAbsolutely, the code in question is part of the Nios II architecture specific code in the kernel source tree.
I can't remember the exact location but we can get that for you if you're having difficulty locating it. The kernel source code can be found in:$KERNEL_PLUGIN/linux-2.6.x After modifying the code, you will need to rebuild your kernel via the IDE. HINT: If your hardware hasn't changed and you wish to speed up compile time, you can change the project/build/include/nios2_system.h file to read only. That'll prevent it from being re-built and consequently, it should speed up the build time. (If your hardware does change, you'll have to switch the file back to writeable so that it can be re-built...) The above hint won't be necessary in the next release of the Nios II Linux Distribution.
