21 years agoLinux application debug problem
Hello, I'm having problems debugging a Linux application using Eclipse. I followed the steps in the "Microtronix Nios II Linux Distribution Reference Guide" document and I get the following...
21 years agoNo, that is *not* normal at all. Which version of Nios II Linux are you running and which version of the Nios II processor do you have installed?
Nios II Linux v1.2 and below work with the Nios II v1.01 and below distributions. Nios II Linux v1.3 works with the Nios II v1.1 distribution. This is because some of the command line options for nios2-gdb-server have changed between nios II v1.01 and Nios II v1.1...
