12 years agoLinux access to non-Linux memory
I want to write large amounts of data into DDR using the FPGA. This works, and I can store data at the required rate. I want the ARM on the C5SOC chip to be able to process that data. I have ...
11 years agoHi all,
Please help me if you have able to access HPS DDR3 memory for your processing. My problem is: I have used malloc for reserve memory in DS-5 code.so I got one start address.now I pass the same to my DMA write start address .so DMA in qsys will start write data from that location. Now I want to read that location form DS-5 code. so I need to translate that address to read data from HPS DDR3 memory? if yes ,How? Thanks in advance.
