22 years agoLinux 2.6
Hello all, well, I followed all steps of "Quick Start Quide.pdf", but at the end, when I started the nios2-console through the SDK shell, the answer was: "Linux version 2.6.5-uc0 <vgarcia@cpqd0...
21 years agoHello,
This issue has been resolved. When the Quartus II Programmer uploads the Nios core to the board, a modal dialog pops up: "OpenCore Plus Status" Click Cancel to stop using OpenCore Plus IP... Anyhow, if you click the Cancel button and then try to use the console, the noted behaviour occurs. If you leave the dialog open, the console and board work perfectly. Note that if you click the Cancel button later on, it still locks out console input/output. Joe.
