22 years agoLinux 2.6 fails / gcc missing / NT not supported?
"Configure Kernel" fails for me, the script cannot find HOSTCC. Upon inspection it seems like the installer hasn't installed a native i86 version of gcc, which I asume it should have done. ...
22 years ago --- Quote Start --- originally posted by ken@Jun 2 2004, 09:18 AM it sounds like something went wrong with the installshield that we put together for the nios ii linux distribution. we're going to look into it today by trying to duplicate your environment as closely as possible. can you give me the following info?
(1) what's the latest service pack that you have installed with nt? --- Quote End --- Microsoft ® Windows NT ® 4.0 1381 Service Pack 6 Multiprocessor Free. <div class='quotetop'>QUOTE </div> --- Quote Start --- (2) Did you install a second Cygwin environment on your workstation (outside of the one that's provided with Quartus/Nios II)? If you did, I'm assuming that you installed it from the Cygwin website?[/b] --- Quote End --- Yes, I had one Cygwin environment installed from earlier, and it is from the Cygwin website. <div class='quotetop'>QUOTE </div> --- Quote Start --- (3) Can you confirm that you're using Quartus II 4.0 SP1 and Nios II Development Kit v1.0?[/b] --- Quote End --- Yep, Quartus II 4.0 SP1. NIOS II SDK Shell output:
Welcome To Altera SOPC Builder
Version 4.00, Built Mon Nov 10 16:27:12 PST 2003
Welcome to the Nios II Development Kit
Version 1.0, Built Tue Apr 27 22:05:27 PDT 2004
Example designs can be found in
/cygdrive/d/progs/altera/kits/nios2/examples
------------------------------------------------ <div class='quotetop'>QUOTE </div> --- Quote Start --- (4) Where did you install Quartus and Nios II?[/b] --- Quote End --- D:\progs\quartus D:\progs\altera (i.e., D:\progs\altera\kits\nios2) <div class='quotetop'>QUOTE </div> --- Quote Start --- (5) Do you have any previous versions of Quartus / Nios / Nios II lying around in your environment that haven't been uninstalled?[/b] --- Quote End --- No. I installed Quartus, Quartus SP1, the NIOS II package a few days ago, there were no FPGA tools installed on my computer before that. <div class='quotetop'>QUOTE </div> --- Quote Start --- If there's anything else that you think we should know regarding your environment, that will help too. [/b] --- Quote End --- It's a SMP machine with two processors, but that seems irrelevant... Also, the Installshield seemed to take a long time before doing anything when started, but I assumed it was unpacking something (and it's only a 550 Mhz machine). <div class='quotetop'>QUOTE </div> --- Quote Start --- Once we get the details, we'll begin the process of trying to duplicate the problem and we'll keep you updated with our progress.[/b] --- Quote End --- Thanks.
