22 years agolinux - console
Hello, I would like to enable uart for the default console. I modified the kernel configuration in Nios IDE to enable UART console and by reprogramming the kernel into the flash, the kernel me...
22 years agoI'm assuming that you're using init and agetty to start up your console. In that case, it sounds like you need to modify the filesystem project a little bit to reflect your new kernel.
In your filesystem project, the file/etc/inittab must be modified as specified below Comment out the following line... ttyJ0:vt100:/bin/agetty 115200 ttyJ0 Uncomment the following line... ttyS0:vt100:/bin/agetty 115200 ttyS0 Once the changes have been made, build and upload your filesystem to your target board. Hope it helps.
