16 years agolibmpeg2dec-0.5.1 problems
Hi everyone, My problem is still the same as in this thread http://www.alteraforum.com/forum/showthread.php?t=16937 but all the links from there are dead meanwhile, so i'll respawn this he...
16 years agoHi,
About 'Welcome.mpg', I'm sorry that it includes audio data. So with the switch '-t'
./mpeg2dec -t Welcome.mpg
we can see the beautiful sand art. For Nios CPU, we already have the directory '/uClinux-dist/lib/mpeg2dec', and we can select it from the 'menuconfig'. So.
make menuconfig
Kernel/Library/Defaults Selection ---> <Select>
Customize Application/Library Settings < Exit > < Exit >
Library Configuration ---> <Select>
Build libmpeg2 < Exit > < Exit >
. Before to 'make', please modify the file '/uClinux-dist/lib/mpeg2dec/mpeg2dec-0.4.1/configure' line 23984 like
echo "$as_me:$LINENO: checking if libtool supports -prefer-non-pic flag" >&5
echo $ECHO_N "checking if libtool supports -prefer-non-pic flag... $ECHO_C" >&6
mkdir ac_test_libtool; cd ac_test_libtool; ac_cv_libtool_non_pic=no
echo "int g (int i); static int h (int i) {return g (i);} int f (int i) {return h (i);}" >f.c
echo "int (* hook) (int) = 0; int g (int i) {if (hook) i = hook (i); return i + 1;}" >g.c
../libtool --mode=compile $CC $CFLAGS -prefer-non-pic
-c f.c >/dev/null 2>&1 &&
-c g.c >/dev/null 2>&1 &&
../libtool --mode=link $CC $CFLAGS -prefer-non-pic -o libfoo.la
-rpath / f.lo g.lo >/dev/null 2>&1 &&
ac_cv_libtool_non_pic=yes
cd ..; rm -fr ac_test_libtool; echo "$as_me:$LINENO: result: $ac_cv_libtool_non_pic" >&5
echo "${ECHO_T}$ac_cv_libtool_non_pic" >&6
if test x"$ac_cv_libtool_non_pic" = x"yes"; then
# LIBMPEG2_CFLAGS="$LIBMPEG2_CFLAGS -prefer-non-pic" <-- line 23984
LIBMPEG2_CFLAGS="$LIBMPEG2_CFLAGS -fPIC"
else
fi
. (Without this,we have some relocation bugs that is caused the dynamic linking.) After the compilation, you can get 'libmpeg2.so.0' and 'libmpeg2convert.so.0' in '/usr/lib' automatically, but copy 'mpeg2dec' in the directory 'uClinux-dist/lib/mpeg2dec/build/src/.libs' by yourself to the adequate directory e.g. '/usr/bin' with 'nokia7_dual.bit'. And please execute
./mpeg2dec -o pgm nokia7_dual.bit
In my NEEK, the result is fine. Kazu
