22 years agoLevel Detected Interrupts for PIO
If a PIO is configured to generate interrupts when a "Level" is detected, how should I handle this in my interrupt service routine? I see the example for edge detected inputs in "count binary", but ...
22 years agosmfelsher,
By defining the interrupt as level sensitive, you are stating that the following behavior is what you want: irq = |(irq_mask & pio_data) This means that if any of the bits in pio_data and the corresponding bit in irq_mask are high, the irq will be generated. If you're looking for something that detects events on each and every bit, I think you'd be happier with edge_capture. The edge_capture register will also hold event values until it is cleared (by writing to it). I hope this helps. Best Regards, slacker P.S.: You could use your IRQ_MASK settings to define different sorts of interrupt events. It all depends upon what sort of hardware you're trying to interface with... P.S.: Even if you're not an HDL expert, looking at what happens in the verilog or VHDL that's generated with any of the various PIOs is a useful exercise to understand what the hardware is doing.
