17 years agoLCD framebuffe problem
I have taken the NEEK kit and adapted a different LCD screen to it. The new screen is 640 x 480, instead of the touchscreen that comes with the NEEK kit. I enabled the PS2 mouse and modified the fi...
17 years agoHi Schaney,
I was able to increase the resolution from 640x480 to 800x600 by changing only the same file as you (altfb.c). You probably did this already, but make sure you 'make clean' your zImage, and to be extra sure you can manually remove all object files inside the microwin folder. Good luck, Ricardo.
