21 years agolan91c111 quiestion
I use standalone single threaded lwIP realization. And I have found that initialization procedure for lan91c111 doesn't pass if I didn't insert active network cable to it. So all program execution stops untill cable is inserted. This is wery bad for single threaded application, cuase I need program to do another job without waiting cable insertion, and lan is used from time to time to get some statistics.
Does someone knows How can I bypass this trouble?1 Reply
If ethernet cable not pluged than function "int alt_avalon_lan91c111_init(alt_avalon_lan91c111_if *dev)", from lan91C111 HAL library, return NON ZERO code.
Call graph: 1. netif_add() 2. lan91c111if_init() 3. low_level_init() 4. atl_avalon_lan91c111_init() 5. configure_phy() Initialisayion of LAN91C111 device failed by time-out in configure_phy(dev) function at this code:
5. configure_phy(): ret_code = -EIO; 4. alt_avalon_lan91c111_init(): ret_code = -EIO; 3. low_level_init(): return (err_t)ERR_IF; 2. lan91c111if_init(): return (err_t)ERR_IF; 1. netif_add(): return NULL For avoid program HALT you may check netif_add return code and if it is NULL try recall netif_add function./* Start the Auto Negotiation process */ /* Try to negotiate, we have a go at this five times if it fails */ i = 5; do { write_phy_register( dev, ALTERA_AVALON_LAN91C111_PHY_CONTROL_REG, ALTERA_AVALON_LAN91C111_PHY_CONTROL_ANEG_EN_MSK | ALTERA_AVALON_LAN91C111_PHY_CONTROL_ANEG_RST_MSK); /* This may take a few seconds */ timeout = 20; do { value = read_phy_register(dev, ALTERA_AVALON_LAN91C111_PHY_STATUS_REG); timeout --; usleep(500000); }while (!(value & ALTERA_AVALON_LAN91C111_PHY_STATUS_ANEG_ACK_MSK) && (timeout > 0)); i --; } while( (i != 0) && (timeout == 0)); if (timeout == 0) { ret_code = -EIO; goto exit; }
