21 years agoLan91c111 daughtercard support for NiosII
I am looking at modifying the NiosII ethernet examples to support the reduced pin configuration (only 24pins vs 72) of the Lan91C111 daughtercard that altera seems to have abandoned. QuartusII4.1 su...
21 years agoI did get the posted driver code to work for me with some changes.
My hw had some problems initially, so you may just want to try the code as is. I believe for the posted code, you will need to connect A1,A2,A3 and SBE0,SBE1. The registers will be on 16bit boundaries. If you want to go the route I went, do the following: My interest was in a minimal pin count interface (24pins). You could also save another 8pins using an 8bit bus. I followed the CPU32 connection scheme for 16bit bus using A2,A3,A4 and SBE1#. This places all registers on full word boundaries. I changed the class.ptf to use native rather than dynamic address alignment. I modified the ..regs.h file to support the above changes. There were a few fixes needed in the alignment code of the low level data transfer functions, and the mac address/ip address code. For simplicity, turn off dhcp in LWIP and use a static IP to test with.
