21 years agoLan91c111 daughtercard support for NiosII
I am looking at modifying the NiosII ethernet examples to support the reduced pin configuration (only 24pins vs 72) of the Lan91C111 daughtercard that altera seems to have abandoned. QuartusII4.1 su...
21 years agoAside from the PDF document mentioned above, is there an actual schematic for this card?
Nate, how did you make the pin assignments for your modified code? I am following the daughtercard docs for a 32bit CPU and I see you have reduced the address bus to [3..0] so I cannot use A2,A3,A4 as described. I believe your code requires the use of a byte enable as well. I went ahead and use A1,A2,A3 (16bit cpu config) and most of the code does execute OK. The telnet example I am trying doen't crash, but I do see some incorrect accesses. It looks like all short accesses are converted to two byte accesses. I see accesses to odd offsets which I don't think will write correctly without the byte enable. Anyway, let me know what your test configuration was. thanks,
