21 years agoLan91c111 daughtercard support for NiosII
I am looking at modifying the NiosII ethernet examples to support the reduced pin configuration (only 24pins vs 72) of the Lan91C111 daughtercard that altera seems to have abandoned. QuartusII4.1 su...
21 years agotns asked
"Is it possible for users to add new components to the NiosII HAL?." Yes, and if you look in the Nios II Software Developers Handbook Chapter 5 tells you how to go about this. "I know that this card worked under NiosI, but with different drivers/sw. Is anyone familiar with this card, or if the hw module for this configuration should work under NiosII/uCos/Lwip once a proper driver is written? " It should be possible to modify the existing driver to work with this card. If you modify the existing driver then from memory I think you need to look at the routines which transfer data to/from the lan91c.
