21 years agoLAN91C111 and DMA
According to NIOS II 5.0 errata, LAN91C111 doesn't handle properly bursts from a DMA, because ARDY signal is not monitored. Could some of you workaround this problem? I need to send da...
21 years agoSo if I understand it right, the increased wait states will slow down the single-cycle access, but allow DMA xfers?
If you aren't using DMA, does it make sense to stick with the old settings?
