19 years agokernel terminal after it shows PID hash ...
I have nios2linux 1.4.1 run on my customed board.
The board has a 2MByte Nor Flash, a 8MByte SDRAM and they work rightly. The layout of flash memory is: 0x200000 ~ 0x304FFF Kernel 0x305000 ~ 0x3FFFFF File System when the system boots, it shows " uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root = PID hash table entries: 64 (order: 6, 1024 bytes) " Then, the system halts. What's wrong? What does the PID hash table entries mean?2 Replies
There is not thing to do with PID.
It might be problem of irq vector. Did you set your irq vector to sdram? Please read the nios wiki. It would be easier if you follow the wiki. - Altera_Forum
--- Quote Start --- originally posted by hippo@Jan 5 2007, 08:26 PM there is not thing to do with pid.it might be problem of irq vector.
did you set your irq vector to sdram?
please read the nios wiki. it would be easier if you follow the wiki.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20387)
--- quote end ---
--- Quote End --- great! I have set the irq (exception) vector to sdram, now it's ok!
