21 years agoKernel reboot using LCD
Hi all, I am trying to use OPTREX LCD module on uclinux ( stratix II board ). I´m using J15 connector to avoid conficts with compact flash card. I have my own display driver designed using...
21 years agoHello Ken,
I´m using IORD and IOWR macros IOWR(PIO_LCD_0_BASE,0,0); IORD(PIO_LCD_0_BASE,0); The problem was solved : I put the code on lcd_16207.c file into main file application (lcd.c) and now the LCD is OK. Problably Eclipse is causing the problem. Thanks for help
