21 years agoKernel reboot using LCD
Hi all, I am trying to use OPTREX LCD module on uclinux ( stratix II board ). I´m using J15 connector to avoid conficts with compact flash card. I have my own display driver designed using...
21 years agoHello Ken,
First I created a new 11 bit PIO and write a simple C program to run on NIOS II. The project has 2 files named lcd_16207.h and lcd_16207.c and I can control the LCD using this option. Then I created a new linux application project and put lcd_16207.* files into the new project. When I run the application the kernel reboot when acessing IO from LCD.
