21 years agoKernel panic - not syncing: No init found.
After successfully starting the kernel I get an error message Kernel panic - not syncing: No init found. Try passing init= option to kernel. After mounting the rootfs it can't find ...
21 years agoAfter building the same kernel with ethernet support, I get a slightly different output:
Freeing unused kernel memory: 64k freed (0x217c000 - 0x218b000)
Warning: unable to open an initial console.
Kernel panic - not syncing: No init found. Try passing init= option to kernel. Now I get the warning, that the initial console could not be opened. The console is JTAG-UART. The device file has major,minor 5,1.
