21 years agoKernel module compiling/loading
After a couple of days of trying, we've finally successfully compiled a 'hello world' module and was able to load it under NiosII uClinux v1.3. Along the way we found 2 bugs that caused major problems: 1) Problem: Stage 2 of the module compile doesn't work under Cygwin (Nios II SDK shell). The modpost.exe program is not correctly reading in the Module.symvers file since Module.symvers has DOS line endings. Solution: run dos2unix on Module.symvers (in the kernel build directory) before trying to compile your module. A better solution would be to fix modpost.exe (read_dump() function in scripts/mod/modpost.c) to handle DOS line endings. 2) Problem: Module wouldn't load using insmod. Unresolved symbol error for printk. After tracking this down we found that the problem was that the ksymtab table was not long-word aligned. Solution: Change /linux-2.6.x/arch/nios2nommu/kernel/vmlinux.lds.S to add . = ALIGN(4); before the ksymtab section. So it should look something like: /* Kernel symbol table: Normal symbols */ . = ALIGN(4); __start___ksymtab = .; *(__ksymtab) __stop___ksymtab = .; These 2 changes fixed all of the problems we were seeing. Hope this helps. -- Terry GraessleNo RepliesBe the first to reply
