20 years agokernel init problem
Hi We have developed our own board with an Altera Stratix II and NIOS II Standard CPU. We download the kernel (2.6.16.11) to the SDRAM (32MB) using nios2-download, and nios2-terminal gives us t...
20 years agoThank you. This solved our problem.
Hein --- Quote Start --- originally posted by hippo@Jul 12 2006, 03:37 PM yes, it is irq related.
note, the interrupt vector (ie, exception vector) should be in uclinux program memory, ie sdram. note in linux, irq 0 used to be auto-detected and that is not supported in nios ii, so you should not use irq 0 for your devices. only timer_0 may use irq 0.
so you have to update in sopc builder, change exception vector to sdram.
and assign irq of smc91111 to non-zero value. then regenerate the new sof.
see,
http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux)
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16833)
--- quote end ---
--- Quote End ---
