20 years agokernel image in SDRAM but not booting?
Hello: I have used the u-boot successully coping the uclinux kernel image from flash to sdram .I verified the contents at and near the start address of the sdram , same with the kerne...
20 years agoHi, Scott
I boot uClinux sucessfully by u-boot . Thank you again. My steps: 1. Modify <u-boot>/include/configs/PK1C20.h to meet my custom board 2. make PK1C20_config 3. make 4. Start HyperTerminal with the following settings: baudrate : 115200 parity : None data bits : 8 stop bits : 1 flow cntl : None 5. nios2-download -g u-boot I saw the command promt "==>". :-) =================================================== TODO: My custom board using Davicom's DM9000A(DM9000X serials). I'd like to using tftp by U-boot. So: 1. copy dm9000x.c dm9000x.h from original u-boot 1.3.1 2. modify some codes to remove some errors and meeting my custom board 3. make 4. nios2-download -g u-boot 5. in the terminal: ==> ping 218.192.171.46 dm9000 not found at 0x00200920 id: 0xffffffff MAC: ff:ff:ff:ff:ff:ff operating at unknown: 15 mode transmission timeout transmission timeout ping failed; host 218.192.171.46 is not alive * Maybe IO routes doesn't work well. * Another questions, I using MTD patitions over Flash. How can I access patitions in u-boot ? and How in uClinux? * I need egrep in cygwin, but this version of cygwin dose not provide egrep. I copy egrep from redhat, but not worked. what's your suggestions? regards, Will
