20 years agokernel image in SDRAM but not booting?
Hello: I have used the u-boot successully coping the uclinux kernel image from flash to sdram .I verified the contents at and near the start address of the sdram , same with the kerne...
20 years agoHi scott:
I use the u-boot-1.1.3 downloaded from www.souceforge.net I see the readme the mkimag command used as fellow: mkimage -A ppc -O linux -T kernel -C gzip -a 0 -e 0 -n "Linux Kernel Image" -d linux.bin.gz uImage I think the uImage file also is .bin type file,so I use bin2flash comand convert the uImage to uImage.flash,then download to .flash file use nios2-flash-programmer . I don't have the .img file. >It looks like an endian order problem I am sure the niosII is little endian,because in the vmlinux.lds file , "OUTPUT_FORMAT("elf32-littlenios2", "elf32-littlenios2", "elf32-littlenios2")" Best Regards jigdo
