21 years agoKernel development on Nios Linux 2.6 distribution
The Nios II Linux 2.6 distribution is not really biased for kernel development, but since this is all what I have, what way you suggest I should develop my drivers? I understood importing the s...
21 years agoI'm sorry, but I still have a lot of errors with your Makefile. I think the basic environment information is missing...
Here are the error messages : (invoked directly from NIOS II-IDE, Build project option) <div class='quotetop'>QUOTE </div> --- Quote Start --- make -k default make -C /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x O=/cygdrive/c/altera/kits/nios2/bin/eclipse/workspace/Kernel_DemoBoard_LAN/build SUBDIRS=/cygdrive/c/altera/kits/nios2/bin/eclipse/workspace/testModule modules make[1]: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x' /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/Makefile:421: /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/i386/Makefile: No such file or directory gcc: not found make[2]: *** No rule to make target `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/i386/Makefile'. make[2]: Failed to remake makefile `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/i386/Makefile'. gcc: not found Using /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x as source for kernel gcc: not found *** Warning: Overriding SUBDIRS on the command line can cause *** inconsistencies gcc: not found HOSTCC scripts/basic/fixdep gcc: not found make[3]: *** [scripts/basic/fixdep] Error 127 make[3]: Target `__build' not remade because of errors. make[2]: *** [scripts_basic] Error 2 make[2]: Target `modules' not remade because of errors. make[1]: *** [modules] Error 2 make[1]: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x' make: *** [default] Error 2[/b] --- Quote End --- It appears that architecture information is missing, as Cross-compiler. So I tried to add 'ARCH=nios2nommu CROSS_COMPILE=nios2-elf-' in $(MAKE) command. Result is better, but there is still problems : <div class='quotetop'>QUOTE </div> --- Quote Start --- make -k default make -C /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x ARCH=nios2nommu CROSS_COMPILE=nios2-elf- O=/cygdrive/c/altera/kits/nios2/bin/eclipse/workspace/Kernel_DemoBoard_LAN/build SUBDIRS=/cygdrive/c/altera/kits/nios2/bin/eclipse/workspace/testModule modules make[1]: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x' Using /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x as source for kernel *** Warning: Overriding SUBDIRS on the command line can cause *** inconsistencies HOSTCC scripts/basic/fixdep gcc: not found make[3]: *** [scripts/basic/fixdep] Error 127 make[3]: Target `__build' not remade because of errors. make[2]: *** [scripts_basic] Error 2 make[2]: Target `modules' not remade because of errors. make[1]: *** [modules] Error 2 make: *** [default] Error 2 make[1]: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'[/b] --- Quote End --- Don't you have such errors ?
