20 years agoKernel compile error
Here is the output from the compiling process: I use Quartus II 5.1 and NIOS II 5.1 on Windows XP Pro and a Centrino Duo Core laptop. Has anyone seen this before? I have read that the '...
20 years ago --- Quote Start --- originally posted by obr@Sep 20 2006, 04:07 PM i had the same problem as qhavenga - just doing standard nios stuff - no uclinux.
error message when compiling a simple nios application:
8055439 [main] nios2-elf-gcc 16516 fork_copy: linked dll data/bss pass 0 failed, 0x576000..0x576264, done 0, windows pid 16700, win32 error 487
the article http://www.cygwin.com/ml/cygwin/2006-01/msg00782.html (http://www.cygwin.com/ml/cygwin/2006-01/msg00782.html) suggests that there is a conflict with the "logitech process monitor" service and cygwin.
after un-installing my logitech camera (quickcam pro 5000) driver/appl. sw and re-installing nios ide - the problem was gone. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
regards,
ove brynestad
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18368)
--- quote end ---
--- Quote End --- This solved my problem too. The laptop has an integrated logitech camera with drivers preinstalled. Hein
