20 years agoKernel compile error
Here is the output from the compiling process: I use Quartus II 5.1 and NIOS II 5.1 on Windows XP Pro and a Centrino Duo Core laptop. Has anyone seen this before? I have read that the '...
20 years agoI had the same problem as qhavenga - just doing standard Nios stuff - no uClinux.
Error message when compiling a simple Nios application: 8055439 [main] nios2-elf-gcc 16516 fork_copy: linked dll data/bss pass 0 failed, 0x576000..0x576264, done 0, windows pid 16700, Win32 error 487 The article http://www.cygwin.com/ml/cygwin/2006-01/msg00782.html (http://www.cygwin.com/ml/cygwin/2006-01/msg00782.html) suggests that there is a conflict with the "Logitech Process Monitor" service and cygwin. After un-installing my Logitech camera (QuickCam Pro 5000) driver/appl. SW and re-installing Nios IDE - the problem was gone. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Regards, Ove Brynestad
