20 years agoKernel compile error
Here is the output from the compiling process: I use Quartus II 5.1 and NIOS II 5.1 on Windows XP Pro and a Centrino Duo Core laptop. Has anyone seen this before? I have read that the '...
20 years ago --- Quote Start --- originally posted by ghavenga@Sep 11 2006, 01:24 PM i am getting the same error.
i have followed the link you supply, and can find nothing that address the "win32 error 487" / "resource temporarily unavailable" problem.
what in particular in the massive thread you refer to addresses this issue?
thanks,
greg
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18225)
--- quote end ---
--- Quote End --- I think hippo's post is more of a general recommendation.... You should not be using a Windows machine for uCLinux development. The majority of the Wiki, and hippo's postings are with respect to using the gcc/uclibc toolchain and buildroot...on a Linux host platform. If you're going to develop a uCLinux system (Nios II or not), this is the way to go. With respect to your Cygwin error, the Microtronix kit was last updated around the v5.0 release, so I'd bet that it won't work (correctly) with anything above that, though I've not tried it, myself. Cheers, - slacker
