21 years agokernel compilation error
I want to run linux on niosII system and the development board is altera stratix gx. There are three flash in gx development board. When I compile the kernel, the errors happen as this
<div class='quotetop'>QUOTE </div> --- Quote Start --- Kind Description Resource In Folder Location Error *** [_all] Error 2 kernel_1s40 Error *** [arch/nios2nommu/kernel/asm-offsets.s] Error 1 kernel_1s40 Error *** [arch/nios2nommu/kernel/asm-offsets.s] Error 2 kernel_1s40 Error# error Sorry,you dont have na_stratix_gx_epc16_kernel or na_stratix_gx_epc16_kernel_end defined in the core.[/cygdrive/d/altera/nios/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/asm-offsets.c] kernel_1s40 line 144 Error error: `na_stratix_gx_epc16' undeclared (first use in this function)[/cygdrive/d/altera/nios/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/asm-offsets.c] kernel_1s40 Error error: (Each undeclared identifier is reported only once[/cygdrive/d/altera/nios/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/asm-offsets.c] kernel_1s40 Error error: `na_stratix_gx_epc16_end' undeclared (first use in this function)[/cygdrive/d/altera/nios/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/asm-offsets.c] kernel_1s40[/b] --- Quote End --- stratix_gx_epc16 is one of the three flashes in my nios sytem. What's wrong and how to correct it? Thank you !1 Reply
Just a (wild) guess, but have you run something along the following lines?
it is some kind of perl script that extracts a number of variables from the ptf file.$ make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=std_1s10.ptf
