21 years ago
Kernel Build not working
The kernel building process is not working. My error is below, make mrproper fails as well. Any suggestions?
Microtronix Linux Extensions
Version 1.4, Built June 20, 2005
make: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x'
no emulation specific options.
Using /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x as source for kernel
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x is not clean, please run 'make mrproper'
in the '/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x' directory.
make[1]: *** [prepare2] Error 1
make: *** [_all] Error 2
make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x'
    I had this problem, too. but 'make mrproper' solved this problem. I started the Nios2 SDK Shell, changed to directory:
    com.microtronix.nios2linux.kernel_1.4.0\linux-2.6.x
    and run 'make MrProper' by typing in the Nios 2 SDK Shell and it did the job.
    If it doesn't work, maybe you'll have to install a fresh version of your Linux Kit?
    It worked today. I ran "make MrProper" and then "make mrproper" and it worked. It could have been I shut down the computer last night and restarted it this morning.
    Add to the Appendix A of the Nios II Linux Quickstart Guide, Altera Nios II 1c12 Evaluation Kit, disable SMC ethernet device driver when enabling MoreThanIP 10_100_1000
