17 years agoKernal Panic - Not Syncing : VFS:
This is problem .....I,m using Altera Nios ii board .....i'm getting through serial uart.....
:ph34r: :ph34r: :ph34r: :ph34r: :ph34r: Uncompressing Linux... Ok, booting the kernel. Linux version 2.6.25-uc0 ([email protected]) (gcc version 3.4.6)# 15 PR EEMPT Sat Jul 25 05:15:30 IST 2009 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists in Zone order, mobility grouping off. Total pages: 8128 Kernel command line: PID hash table entries: 128 (order: 7, 512 bytes) console [ttyS0] enabled Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: Memory available: 30708k/1760k RAM, 0k/0k ROM (1510k kernel code, 249k data) Mount-cache hash table entries: 512 net_namespace: 144 bytes NET: Registered protocol family 16 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 1024 (order: 1, 8192 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) TCP reno registered io scheduler noop registered io scheduler deadline registered (default) NIOS serial driver version 0.0 ttyS0 (irq = 4) is a builtin NIOS UART smc91x.c: v1.1, sep 22 2004 by Nicolas Pitre <[email protected]> eth0: SMC91C11xFD (rev 2) at 82110300 IRQ 6 [nowait] eth0: Ethernet addr: 00:07:ed:0f:b8:f7 TCP cubic registered NET: Registered protocol family 1 NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. List of all partitions: No filesystem could mount root, tried: Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) What is the solution .....? ................................................................................ ... Regards VivekNo RepliesBe the first to reply
