20 years agokernal build error
dear hippo, Thank you help me , now i bulild the kernal in my custom board (EP1C6,SDRAM(8MB),FLASH(8MB),uart *2,jtat uart ) ,when i run menuconfig ,i select the ALTERA JTAG UARTsupport,a...
19 years agoI follow the step in the new wiki,
http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist) Where you guys getting this error: I tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operating...ems/framebuffer) but I ran into this error when trying to run make in the uClinux-dist/ fs/buffer.c: In function `__find_get_block_slow': fs/buffer.c:292: warning: long unsigned int format, size_t arg (arg 3) LD fs/built-in.o CC drivers/char/tty_io.o In file included from include/linux/selection.h:11, from drivers/char/tty_io.c:103: include/linux/vt_buffer.h:18:21: asm/vga.h: No such file or directory make[3]: *** [drivers/char/tty_io.o] 错误 1 make[2]: *** [drivers/char] 错误 2 make[1]: *** [drivers] 错误 2 make[1]: Leaving directory `/home/nios/download/uClinux-dist/linux-2.6.x' make: *** [linux] 错误 1
