20 years agokernal build error
dear hippo, Thank you help me , now i bulild the kernal in my custom board (EP1C6,SDRAM(8MB),FLASH(8MB),uart *2,jtat uart ) ,when i run menuconfig ,i select the ALTERA JTAG UARTsupport,a...
19 years agoThe zImage load address is ( your sdram base address + link address offset ) .
You problem is cuased by the sof. The sof included in the DE2 disc (v1.3,v1.4,v1.5) is no good. You should recompile the sof or use older sof, the one attached in the wiki is v1.1 .
