20 years agokernal build error
dear hippo, Thank you help me , now i bulild the kernal in my custom board (EP1C6,SDRAM(8MB),FLASH(8MB),uart *2,jtat uart ) ,when i run menuconfig ,i select the ALTERA JTAG UARTsupport,a...
20 years ago --- Quote Start --- originally posted by iriver@Jun 4 2006, 09:14 PM for these command:
cd uclinux-dist-test
zcat uclinux-dist.diff.gz | patch -p0
i want to known the where the uclinux-dist.diff.gz i should palce!
the uclinux-dist-test dir or anywhere???
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15882)
--- quote end ---
--- Quote End --- You can place it in uClinux-dist-test, but anywhere should work if you give the path.
