20 years agokernal build error
dear hippo, Thank you help me , now i bulild the kernal in my custom board (EP1C6,SDRAM(8MB),FLASH(8MB),uart *2,jtat uart ) ,when i run menuconfig ,i select the ALTERA JTAG UARTsupport,a...
20 years ago --- Quote Start --- originally posted by hippo@May 31 2006, 11:15 AM it may be
1. problem of sdram timing or hardware, you should run some sdram test or hello on ide/hal .
2. byteblaster is not stable, altera recommend usb blaster for nios2 download.
try add termination to jtag signal on your board.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15704)
--- quote end ---
--- Quote End --- You have 8MB sdram, you should set boot loader offset to 5M in kernel config. http://nioswiki.jot.com/wikihome/operating...nux/linuxconfig (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/linuxconfig) cd ~/uClinux-dist-test make menuconfig Kernel/Library/Defaults Selection ---> (linux-2.6.x) Kernel Version (None) Libc Version [ ] Default all settings (lose changes) [*] Customize Kernel Settings [ ] Customize Vendor/User Settings [ ] Update Default Vendor Settings Then <exit> <exit> <yes> <div class='quotetop'>QUOTE </div> --- Quote Start --- If you use DEII with 8M sdram, change the link address of the uncompress loader, Processor type and features-->(0x00500000) Link address offset for booting. The zImage load address is ( your sdram base address + link address offset ) . The zImage boot loader does not relocate itself.[/b] --- Quote End --- Then "make" again.
