20 years agokernal build error
dear hippo, Thank you help me , now i bulild the kernal in my custom board (EP1C6,SDRAM(8MB),FLASH(8MB),uart *2,jtat uart ) ,when i run menuconfig ,i select the ALTERA JTAG UARTsupport,a...
20 years agoIt may be
1. problem of sdram timing or hardware, you should run some sdram test or hello on IDE/HAL . 2. byteblaster is not stable, altera recommend usb blaster for nios2 download. Try add termination to jtag signal on your board.
