21 years agoJust wanted to make sure of some things..
Hello, Recently I got a hold of a NiosII Evaluation kit, and just had a couple questions on what is possible or not with an embedded fpga system like this with a processor. I have worked with F...
20 years agoHi Scott,
I too have just purchased a Nios II Evaluation Kit and am trying to figure out how to rebuild uCLinux, Ethernet MAC, and SDRAM controller. The tutorials that came with the kit speak primarily of a "Development" kit. I also want to write a very simple udp application to send packets out of the Ethernet interface but the filesystem appears to be set up as a ramdisk. I.e. whatever I do, I lose when I reboot. Finally, the Linux won't boot up unless I plug the USB cable into it and launch a console session. Do you have any advice on where I can go to find some tutorials / information on how all this works?! Thanks, Wade --- Quote Start --- originally posted by smcnutt@Aug 25 2005, 05:48 PM hi mark,
> is it possible to run the uclinux distro on it,
yes.
> and as well have stand-alone fpga programs running as well?
i'm not sure what you mean by "stand-alone fpga programs" ... but here goes:
-yes, you can write your own applications that run under uclinux.
-yes, you can write your own applications that use the hal (no linux).
-no, you can't run them at the same time.
> an example would be me running an adc program
... snip ...
> and then in turn, output it via ethernet.
yes, this is where uclinux and nios ii are a great match. you can do this with
a simple device driver and a simple application. you could even setup the web server
to monitor data via a browser.
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=9277)
--- quote end ---
--- Quote End ---
