21 years agoJust wanted to make sure of some things..
Hello, Recently I got a hold of a NiosII Evaluation kit, and just had a couple questions on what is possible or not with an embedded fpga system like this with a processor. I have worked with F...
21 years agoHi Scott,
>Assuming even a meager 8-bits/sample, that's > 800 Mbps ... you better start thinking about something faster >than Gigabit Ethernet! For the application that Im going to be using it for, it would have it be counting pulse width, height, and frequency, so I wouldnt need to be sending a stream of this data over the ethernet, just a numbers after it has been sorted out on the FPGA side. Thanks for clearing up the FPGA / linux stuff, but I still feel lost on how its all setup on this board and whats runnning and where, etc. But Ill check into it a bit more later on, certainly have enough docs on it. Thanks for your help! -Mark
