21 years agoJust wanted to make sure of some things..
Hello, Recently I got a hold of a NiosII Evaluation kit, and just had a couple questions on what is possible or not with an embedded fpga system like this with a processor. I have worked with F...
21 years agoHi Mark,
> Is it possible to run the uClinux distro on it, Yes. > and as well have stand-alone FPGA programs running as well? I'm not sure what you mean by "stand-alone FPGA programs" ... but here goes: -Yes, you can write your own applications that run under uClinux. -Yes, you can write your own applications that use the HAL (no Linux). -No, you can't run them at the same time. > An example would be me running an ADC program ... snip ... > and then in turn, output it via ethernet. Yes, this is where uClinux and Nios II are a great match. You can do this with a simple device driver and a simple application. You could even setup the web server to monitor data via a browser. Regards, --Scott
