20 years agoJUART / nios2-terminal bandwidth limit
We are trying to use a part of a StratixII as a RS232 server : - 6 uarts, at 9600 baud, are connected to the outside world : actual computers - Data from the 6 uarts are "routed" by a NI...
20 years agoYou did not say which software are you using on the device... is it the standard Altera HAL?
did you try to use non-blocking writes? what do you use for the communication among the two CPUs? bye Paolo
