21 years agoJTAG Warning
For some reason, my software doesn't run (using terminal mode for configuration) and I keep getting the following messages: nios2-terminal: connected to hardware target using JTAG UART on c...
21 years agoWhatever caused the problem, it's wasn't the JTAG or Software (something subtle must have happened in the firmware). I took quite a few steps back (stripped my design) and was finally able to successfully run some code. Then I added my peripherals and software back, piece by piece, and I never ran into again! I'll post it if I find out what it was.
