21 years agoJTAG Warning
For some reason, my software doesn't run (using terminal mode for configuration) and I keep getting the following messages: nios2-terminal: connected to hardware target using JTAG UART on c...
21 years agoThe output from the Nios II download window often explains what is going on better than the nios2-terminal window. If you can rerun your test and say what's in that window then it might be more obvious what's going on.
