21 years agoJTAG Warning
For some reason, my software doesn't run (using terminal mode for configuration) and I keep getting the following messages: nios2-terminal: connected to hardware target using JTAG UART on c...
21 years agoIf you have a System ID peripheral I recommend turning on the check (better make sure that you have the right hardware first).
Can you describe what your cable looks like? (short or long ribbon, shielded (yellow) ribbon, etc...)
