21 years ago
JTAG UART error?
I'm wondering if my problem is with the JTAG device?
In my post from the 24th, I removed all of my network stuff (from the kernel and hardware). System changes that I have made are
1) increased I/D cache
2) removed my on-chip memory (using EP2C35 FPGA, so not a lot of spare internal memory)
3) put my network stuff back in.
My system now makes it to the log-in; however, I still usually get login incorrect, or I can only hang out in the terminal for a short period of time before I end up back at the login prompt.
I updated my rc file to set my IP address during boot up. I can telnet into my system without any problems, ping it, hang out in the terminal as long as I want, and the web server stays on-line as well.
Since I can remotely login without any problems, I tend to think my problem is with the JTAG interface. I tried to increasing my jtag_uart buffer sizes, irq thresholds, and the irq value as well. Increasing the thresholds only seem to make the problem worse, and changing the irq value did not seem to have any effect at all, and the buffer size didn't seem to make any changes either.
Here is a copy of what I see now.
setup_arch: No persistant network settings signature at 00FF0000
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 1024 (order: 10, 16384 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory available: 128000k/131072k RAM, 0k/0k ROM (1420k kernel code, 289k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x80000860 (irq = 7) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
smc_probe: 75000 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x8001030ÿ IRQ:3 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:ed:00:00:00
Altera NDK flash (AMD): Found 1 x8 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Altera NDK partition definition
Creating 2 MTD partitions on "Altera NDK flash (AMD)":
0x00200000-0x00600000 : "romfs/jffs2"
0x00000000-0x00200000 : "loader/kernel"
NET: Registered protocol family 2
IP: routing cache hash table of
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
NET: Registered protocol family 17
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 60k freed (0x818c000 - 0x819a000)
^@^@^@^@^@^@^@^@expand: from=/ramfs.img to=/dev/ram0
expand: from=/ramfs.img to=/dev/ram1
eth0:PHY 100BaseT
eth0:PHY Full Duplex
/etc/issue www.microtronix.com June 2005
Welcome to Linux on the Nios II
Nios2 login:
Doug
    It looks like the output that you're seeing is coming from your rc file. Can you post it or pm a copy to me? I'll see if I can pin down what might be causing it.
    er... quick question... that is what you&#39;re asking about right? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
    Ken,
    I don&#39;t think my problem is with my rc file, but by all means take a look at it.
    I think my problem is with the JTAG UART. At this point, I&#39;m not really sure. I can log into my system through the ethernet port and all works just fine.
    My problem seems to be the console, you can see the garbage I get out below. Sometimes it is worse, usually not better. Often when I log in through the console, I get Login Incorrect. When I am able to log in, I usually get booted out within 20 or 30 seconds. If I use the IDE to load my new kernel, I get an "m_state == STATE_DEBUG" error, usually before I get 25% of the code downloaded (it comes in at random times).
    Doug
    # !/bin/sh# # system startup.
    # set up the hostname
    /bin/hostname Nios2
    # expand and mount the ramdisk
    /bin/expand /ramfs.img /dev/ram0
    /bin/mount -t ext2 /dev/ram0 /var -n
    /bin/expand /ramfs.img /dev/ram1
    /bin/mount -t ext2 /dev/ram1 /tmp -n
    # mount proc file system
    /bin/mount -t proc proc /proc -n
    # mount sysfs
    /bin/mount -t sysfs sysfs /sys -n
    # manually assign ip address (uncomment and edit as appropriate)# note: first ifattach (no args) sets local loopback# /bin/ifattach
    /bin/ifattach --addr 129.57.93.54 --mask 255.255.252.0 --net 129.57.92.0 --gw 129.57.92.1 --if eth0
    # try and get ip address automatically...# /bin/mkdir /var/dhcpc# /bin/dhcpcd -NRY &
    # start up the internet superserver
    /bin/inetd &
    # start up the web server
    /bin/boa &
    # mount Linux server:# (uncomment and edit as appropriate)# /bin/mount -t nfs 192.168.1.30:/home /mnt/nfs -n -o nolock
    # mount master ide disk partition(s):# (uncomment and edit as appropriate)# /bin/mount /dev/hda1 /mnt/ide0 -n
    # that&#39;s it... success
    exit 0
    Yup... you&#39;re right, your rc file is definitely clean... looks downright... standard. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
    From the symptoms you&#39;re describing, I&#39;m definitely more inclined to agree with you. Some things that you may want to try if possible:
    (1) Try a different ByteblasterMV or USB-Blaster cable and see if the symptoms persist
    (2) Switch over to using a Serial DB9 connection for your console
    Since you&#39;re on a custom board, I have no idea if the above is applicable or even possible. But I&#39;ll hope that you&#39;ll give it a try. Buys me some time to think about the issue. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
    Ken,
    I&#39;ll try another cable and get back with you. However, my cable does work just fine for standard FPGA/config device prgramming. It even works great with my custom flash programmer.
    I can&#39;t use DB9, not included.
    Doug
    Slacker,
    Interesting, thanks for the update and link. I think you&#39;re on to something here.
    Ken,
    I managed to dig up my ByteBlasterMV cable. That works just fine, no problems. After reading the link Slacker gave me, I need to put the JTAG signals on a scope.
    Thanks for the help guys,
    Doug
