CXian8
7 years agoJTAG pin sharing with NIOS
hi all, I have a max10 board, on which the JTAG pins should be used as normal IO. I found that, if a NIOS subsystem is initiated in my design, the fitter would complain about pin assignment confilic...
AnandRaj_S_Intel
7 years agoHi Chao,
Enable JTAG pin sharing also read about JTAGEN
Please refer below link session 3.1 for Dual-Purpose Configuration Pins.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Also please share below information.
- Can you post the pin assignment conflict message?
- Which Development Kit are you using?
- Quartus tool version used?
Anand
