16 years ago
Jtag or console driver problem?
I use the NEEK board to test the application code with no MMU.
printf("%s::%d %s\n", __FUNCTION__, __LINE__, buff);
Note: The buff is current time string, and run once percent 1 second.
When disconnet the JTAG with the host PC, or no nios2-terminal, the application will pause with after about 4k bytes output.
Note: I test once is 4058 bytes.
But I connect the JTAG and nios2-terminal, the application will continue to running.
The driver config:
Character device: only select "Unix98 PTY support"
Serial drivers:
Select 3:
Altera JTAG UART support
Altera JTAG UART console support
Bypass output when no connection
Unselect:
Altera UART support or Altera UART console support
1 Reply
    I try to modify the altera_jtaguart_tx_chars or altera_jtaguart_start_tx function.
    But I am failed.
