15 years agoJTAG on XUBUNTU (VMWare image)
I was able to set up Quartus+Nios on a Xubuntu 10.10, but I cannot figure out what to do with the jtag. Whatever I do, the result is: vmplanet@ubuntu:~$ lsusb Bus 002 Device 003: ID 09fb:6001 Altera Bus 002 Device 002: ID 0e0f:0002 VMware, Inc. Virtual USB Hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub vmplanet@ubuntu:~$ /altera/10.1sp1/quartus/bin/jtagconfig No JTAG hardware available What I tried before is: a) added "usbfs /proc/bus/usb usbfs devmode=0666.0.0 " to /etc/fstab b)added "BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", SYMLINK+="usbblaster" " to 70-persistent-net.rules (the manual says put this line to 40-permissions.rules that does not exist) So, if anybody knows a solution, please help!3 Replies
I wouldn't advocate going over USB to get to your host's USB Blaster. I would use the virtual networking connection instead. You can do this be setting up Quartus II on your host to act as a jtag server (http://quartushelp.altera.com/current/mergedprojects/global/install/install_pro_jtag.htm).
You can then type "jtagconfig --addserver <server> <password>" using the host's IP address (real or virtual) and the password you defined in the process described at the above link. I prefer this method over getting virtual USB to function properly. Though I've gotten both to function, the virtual networking thing is easier...in my opinion. Best of luck! slacker - Altera_Forum
--- Quote Start --- Hi, I was able to set up Quartus+Nios on a Xubuntu 10.10, but I cannot figure out what to do with the jtag. Whatever I do, the result is: vmplanet@ubuntu:~$ lsusb Bus 002 Device 003: ID 09fb:6001 Altera Bus 002 Device 002: ID 0e0f:0002 VMware, Inc. Virtual USB Hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub vmplanet@ubuntu:~$ /altera/10.1sp1/quartus/bin/jtagconfig No JTAG hardware available What I tried before is: a) added "usbfs /proc/bus/usb usbfs devmode=0666.0.0 " to /etc/fstab b)added "BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", SYMLINK+="usbblaster" " to 70-persistent-net.rules (the manual says put this line to 40-permissions.rules that does not exist) So, if anybody knows a solution, please help! --- Quote End --- Some things you should try:- comment out the line you made in a)
- on b) remove it out of 70-persistent-net.rules and write it into "51-usbblaster.rules"
- create an empty file named ".jtag.conf"
Thanks everybody. As I found out later the problem is caused by exclusion usbfs from the Xubuntu Lucid Kernel. The easiest solution is to add
sudo mount --bind /dev/bus /proc/bus sudo ln -s /sys/kernel/debug/usb/devices /proc/bus/usb/devices to rc.local Now I have a VMware Xubuntu image with installed Quartus, Nios and working USB-Blaster. Maybe it makes sense to share it :)
