15 years agoJTAG on XUBUNTU (VMWare image)
Hi, I was able to set up Quartus+Nios on a Xubuntu 10.10, but I cannot figure out what to do with the jtag. Whatever I do, the result is: vmplanet@ubuntu:~$ lsusb Bus 002 Device 003: ID...
15 years agoI wouldn't advocate going over USB to get to your host's USB Blaster. I would use the virtual networking connection instead. You can do this be setting up Quartus II on your host to act as a jtag server (http://quartushelp.altera.com/current/mergedprojects/global/install/install_pro_jtag.htm).
You can then type "jtagconfig --addserver <server> <password>" using the host's IP address (real or virtual) and the password you defined in the process described at the above link. I prefer this method over getting virtual USB to function properly. Though I've gotten both to function, the virtual networking thing is easier...in my opinion. Best of luck! slacker
