20 years agoJTAG issues after 5.1 SP1 and Flash Programmer
Hello all,
I've read several posts concerning JTAG Downloading issues. I have a custom EP2C8 board that I've had similar if not the exact same issues as others here have described. One thing that I did to work around the issue is add enable/disable logic to all of my internal circuitry so that everything boots up disabled. Then after the NIOS boots, it can enable the circuitry. This worked for me. I don't know if it was current draw with all of my circuitry working or internal noise affecting the JTAG circuitry or what, but I do know that by disabling everything, I was able to download code via the JTAG cable. Now that that is out of the way, on to my question. I just upgraded to 5.1 SP1 and tried to go through all the steps to program the EPCS4 with my hardware file and my software file. I've used the command line and the IDE, both fail at the programming stage. I can see the flash being erased. I even once got a success while using the command line and programming just my software file, but I couldn't repeat it. I've read the flash back out and can see that some data is being written, and it closely resembles what is in my software file. I think this is the same old JTAG issue that affected me earlier. Except now, there is a lot more data that is being send over the JTAG cable than just downloading my code. Here is the output from my command line attempt: [SOPC Builder]$ nios2-flash-programmer --epcs --base=800 --debug epcs_controller.flash Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Processor data bus width is 32 bits Looking for EPCS registers at address 0x00000800 (with 32bit alignment) Initial values: 0001703A 04C00074 9801483A 9CFFF804 983FFD1E 0000203A Not here: reserved fields are non-zero Looking for EPCS registers at address 0x00000900 (with 32bit alignment) Initial values: 002EE03A 00000106 6800683A 03010004 93000335 02C0C034 Not here: reserved fields are non-zero Looking for EPCS registers at address 0x00000A00 (with 32bit alignment) Initial values: 00000000 00000000 00000260 00000000 00000000 00000001 Valid registers found EPCS signature is 0x12 EPCS device doesn't support RDID command Using EPCS size information from section [EPCS-12] Device size is 0MByte (4Mbit) Erase regions are: offset 0: 8 x 64K EPCS status is 0x00 : Checksumming existing contents 00020000 : Verifying existing contents 00020000 : Needs erase then program 00030000 : Verifying existing contents 00030000 : Needs erase then program 00020000 : Reading existing contents 00030000 : Reading existing contents Checksummed/read 128kB in 3.0s 00020000 ( 0%): Erasing 00030000 (50%): Erasing Erased 128kB in 10.5s (12.1kB/s) 00020000 ( 0%): Programming Program failed Leaving target processor paused This is very frustrating to say the least. I'm open to suggestions.2 Replies
After reading other posts about adding series resistors to clock lines, I changed my JTAG resistor pack from 10K to 1K. I can now successfully program the EPCS4 using the IDE's Flash Programmer. After looking at the signals more closely with a scope, I noticed that they weren't going up to 3.3V like they should. So I thought a stronger pullup on the lines might help. It seems to have worked for me.
Hey, I seem to be having a related problem (http://forum.niosforum.com/forum/index.php?showtopic=3357). Click the link for my topic.
