21 years agoJtag debug problem... any suggestion welcome.....
I'm working on my board designed with NiosII and Ep1C20 device, extarnal 16 bit flash and 32 bit dram. I check the tco e tsu for pll shift dram clock, from timing analyzer will be work at 100M...
21 years agoThere are also some proposals from Altera application engineer
that sometimes a small series resistor (about 32ohms) in DCLK helps , so placing a R-C combination in layout is a good idea.
