21 years agoJtag debug problem... any suggestion welcome.....
I'm working on my board designed with NiosII and Ep1C20 device, extarnal 16 bit flash and 32 bit dram. I check the tco e tsu for pll shift dram clock, from timing analyzer will be work at 100M...
21 years agoI try to realize a smal project with sram block inside ad minimum requirements, i choose internal ram as target in IDE library properties but the result is the same..... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif
roby
