21 years agoJtag debug problem... any suggestion welcome.....
I'm working on my board designed with NiosII and Ep1C20 device, extarnal 16 bit flash and 32 bit dram. I check the tco e tsu for pll shift dram clock, from timing analyzer will be work at 100M...
21 years agoYesss, i have programmed the flash with flash programmer inside the IDE and HW custom project as target.
If there are not other way to understan the origin of problem i will follow your suggestion , a restricted design with only the nios core, flash interface and onchip memory............ http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
